chip dilemanow with graphs
Started by g40chris, May 13, 2009, 08:27:01 PM
g40chris
i have just rebuilt my Polo g40 engine, been off the road for nearly 3 years
just got it through MOT this week
trouble is its a different spec now to what it was when i took it off the road but i still have the custom map in itfor the old spec. i was told earlier that it might be better if i run the car on the standard chip for now until i get a suitable map.
what do you guys think?
here are the differences in the specs:-
the old spec
1308cc carl schmit pistons
eaton charger
amd 55mm pulley
large front mount
aquamist
psd big valve ported head
eaton cam
induction kit
dewedged TB
decat pipe
full stainless steel exhaust
gt inlet manifold
g60 green injectors
new spec
stage 4 g-lader
65mm pulley
g60 green injectors
eaton cam soon to be newman cam
standard intercooler
dewedged TB
decat pipe
full stainless exhaust system
induction kit
gt inlet manifold
can anyone recommend a good chip
been looking at performance polo chips
been looking at the Map #G40005
what you guys reckon
G40supercharged
Don't use a standard chip; the capacity change, injectors, big valve head, cam, and gt inlet will mean the fuelling is completely wrong with a standard chip.
poloeatonm45
i thought the eaton cam was a newman cam?
steve
Chris,
If you can find out what the compression ratio is of the pistons you've got Andy has plenty of maps so should be able to put something together until you can get it custom mapped.
Dan
Who is carl schmit ? Never heard of those pistons ?
Are you sure you don't mean KolbenSchmidt ? They are the original brand fitted.
g40chris
im sure they are carl schmidt
i thought that it would make it run lean with the standard chip
will running it on the eaton chip do the car any damage, seeing as im running the engine in
on my PSD receipt it says something like newman eaton spec cam
Karl Schmidt = USA division of KolbenSchmidt.  :)
If you run it on a standard chip with 250cc injectors it'll overfuel like fook.  Also you last thing you want is it running lean!  I would find out the CR of those pistons (who'd you buy them off?) and then speak to yoof & andy about knocking together a map that'll work.
g40chris
i phoned about the compression ratio earlier
its aw tracksport that originally built my engine and they ordered the pistons for me, i gotta ring to speak to andy. didnt really ever want to deal with them again but i suppose i need to
g40chris
here is a printout from PSD when they done the map
spark advance at middle throttle
vertical scale goes from 0 to 255
not sure what its measured in
left hand side bottom scale goes from 0 to 6500
bottom scale is load but cant make out the numbers
same scale on this but injection at part throttle
does this help anything
polo classic
I'd use the PSD chip you have, it will be the map that will be nearer optimum.
I guess inlet temp wont be far off a Eaton with large intercooler with g-lader, pulley and std ic
g40chris
what about the difference in the amount of boost?
at idle the revs vary between 1000-1500 rpm and sometimes cuts out, would that be the chip causing that or something else.
polo classic
Quote from: g40chris on May 26, 2009, 08:14:24 PM
Idle will be something else
Amount of boost just dictates what part of the map is accessed (the 0-100 scale)
What part of map is used is determined by rpm and mapsensor voltage
