K03 Air Filter Set Ups
Started by Max, April 14, 2009, 09:51:47 PM
Max
Chaps,
What sort of air filter set ups are you running?  I was thinking just a reducer off the turbo onto a bigger straight pipe attached to the filter.  Or maybe work one around something like a Jabba heatshield and filter combo?
Any ideas and pictures would be great!
mines a bit of a mish-mash of bits really.  The inlet to the turbo is tiny really.  I've got a piece of 44mm ID silicon which fits onto the turbo inlet.  Then clamped two pieces of progressively bigger silicon bits I had knocking about in my garage over the top of that, the end result was then big enough to clamp on the ducting and filter I already used with the g-lader.  You could probably buy a reducer that would look nicer but I just used what I had lying about for the time being.
