Boost guage size
Started by josé, March 21, 2009, 02:53:45 PM
josé
Hi, i want to fit a boost guage to my G40, i want to put it in the Drivers side air vent as i never use them, just wondering what size guage would be best suited for this space?? either 52mm or 57mm maybe?
ive measured the vent its about 58mm give or take, was just wondering where people measure the guage faces from inside diameter or outside?
cheers josh
Alexiskayak_7
Well... I've tried to put the gauge inside the air vent.. The only problem is that the vent from the inner side is getting narrower and the gauge can't fit into the vent... If you want you can cut the inner narrow side of the vent and the gauge can fit...
I choosed to put the gauge over there for 2 reasons:
-It's much more easy for the eye
-You won't block the vent
http://www.imageshack.gr/view.php?file=op9m9qblfpeiwzrpe20a.jpg
