Author Topic: my black stielheck  (Read 62642 times)
Offline Thomas
Re: my black stielheck
« Reply #45 on: January 11, 2011, 08:43:28 am »
Hi there and thanx!
"P.P. I think about doing a light-version of the fishbone suspention this spring, if You're interested I'll picture everything that I do and will tell you and all the members about the result of it."
Of course i´m interested in that.
Your manifold flange, did you get it vectorized?
Or is there any ony whos got a drawing?
thomas
Offline Thomas
« Reply #46 on: January 11, 2011, 07:58:13 pm »
Hi
I have been around for a while now and i am deeply impressed with the knowledge u guys have.
So when i now start a new phase of the polo 1WTD´s life some things needs to be sorted.
so!
This week i´ve started a new project, my turbo converted polo diesel will now be updated.
The engine will produce approx. 170bhp and 230Nm.
Now i really need this forums help.
Clutch, what can i use? 200mm?? or even bigger with mods?
Can i use the G40 clutch with my flywheel?
Gearbox is there ant thing u can do to increase the stiffness and strength?
Do i have to do any thing at all??
Gearbox is 8p, ratios, can i change any thing to get the revs down and increase topspeed?
The difference between the gearboxes like che, ceg i.a? i know the ratios are diffrent but is there any thing to gain material wise?
please help is needed fast in this so please help me out here??
thomas
Sweden
Offline Thomas
« Reply #47 on: January 13, 2011, 08:39:22 am »
hi all!!
After beeing surfing around in etka i found out that there is a gearbox called CNU and CWR that have a better ratio then 8p.
The 1.6 (75bhp) ABU engine has these gear boxes apperently.
Is there any info om here or the net about the streghtness of these gearboxes.???
I can se some diffrences in etka on some of the internals, but what it really mean i don´t know.
Is there any one who´s got some info around these 2 boxes in diffrent applications or just experiences please let me know.
thomas
sweden
Offline Thomas
« Reply #48 on: January 21, 2011, 06:26:31 am »
Ok.
The updates goes on and for the time being the removal of the brakes is on the way.
Got me a set of alu calipers with 38mm piston from passat 97.
New seals ordered and will be delivered next week.
Painted the whishbones and the IC tubes are installed properly.
Got my hands on a CHL gearbox te otherday, is there any one who knows the ratios on this box?
I need to change the box if i should be able to get the car through registration as a "modified vehicle".
Next is to drop the rear axle and start a rear dics convertion, any hints on this will be useful.
Found some sleevs for the handbrake wires to reduce travel.
Is there any one whoes gone this way and know if it realy works??
thomas
Sweden
Offline Doc J
  • GT40 - AE86C
« Reply #49 on: January 24, 2011, 12:19:20 pm »
Hi, Thomas,
I've done searching about the vectorized flange file for autocad, but the man that got it told me, that he've lost all info after a virus in his computer :(
If You want You can get a new seal for the exhaust, scan it and send to me the JPEG file. I'll vectorize it and I'll make the outer shape, after that will send you the autocad file ;)
For the rear brake disk convertion You can ask Volkov. He got too much expirience in this work ;)
Offline Thomas
« Reply #50 on: January 25, 2011, 06:41:41 am »
DocJ: thanx for bothering.
Told my friend about this flange and he sorted it for me in catia.
On one of your pics (the one with snow and front wiew) the intercooler is diffrent looks like a bmw525tds ic??changed ??? why?
Due to poor performance maybe?
Did you move the oilfilter???
i mean the turbo is very close.
thomas
Sweden
Offline Doc J
  • GT40 - AE86C
« Reply #51 on: January 25, 2011, 10:08:14 am »
thomas
Sweden
When I bought the car it was with 525tds IC. But I changed it later, because I thing the TDS IC isn't good, it's small...
No, I didn't move the iol filter, I've just bought the shortest possible oil filter and there wasn't any problems with this. ;)
Offline Thomas
« Reply #52 on: January 28, 2011, 04:43:04 pm »
If the tds IC was changed due to the fact its small, did you notice any diffrence??
Started my rear disc conv. yesterday.
Pics any one??
thomas
Offline Volkov
  • Polo Team Bulgaria
    • http://poloteam.alanasoft.com/
« Reply #53 on: January 28, 2011, 10:34:31 pm »
Sorry i saw this topic too late but..
On Polo operation is same
1st remove old drums
When old drums are down every thing should be fine... :D
When they are ready
« Last Edit: January 28, 2011, 10:37:22 pm by Volkov »
Offline Doc J
  • GT40 - AE86C
« Reply #54 on: January 29, 2011, 07:07:13 am »
The bigger intercooler gave a liitle difference when the car was still with G40, but with K03 it was a bit laggy. Now I think about shorter IC - 450mm width insted of the old 550mm.
P.S. What turbo You gonna use? If it's compareable with the K03 - I think the TDS IC will be good enough :)
« Last Edit: January 29, 2011, 07:13:14 am by Doc J »
Offline Thomas
« Reply #55 on: January 30, 2011, 10:06:39 am »
Hi
At the moment the turbo will be from a BMW 525tds as well as the IC.
Don´t know the numbers on the turbo.
Can´t find any info like effektivness etc on this turbo, so if anyone has that info or know were tofind data on this i would appreciate this.
thomas
Sweden
Offline Doc J
  • GT40 - AE86C
« Reply #56 on: February 02, 2011, 02:08:24 pm »
Look at the numbers of the turbo.
Model    Year      Motor     Turbo Number  Alternative        Turbo Model
525 TDS 91-92    2.5 D     2243579         49177-06500     MIT TD04-11G
525 TDS 92-       2.5 D     2243398         465555-2/3       GAR TB2514
525 TDS 93-96    2.5 D     2245147         49177-06540     MIT TD04-11G5
525 TDS 96-       2.5 D     2246144         49177-06451     MIT TD04-13T
525 TDS 96-       2.5 D     2246670         49177-06581     MIT TD04-13T
I bet in the T25 Turbo from 2.5 TDS
If you use a stock 2.5TDS turbo and aim the stock 2.5TDS Torque and Horse power => the stock IC is good enough. For bigger plans a bigger IC is good idea, but think about the lag ;)
In the attached file You can see some turbos used in stock cars. ;)
« Last Edit: February 02, 2011, 02:10:25 pm by Doc J »
Offline Thomas
« Reply #57 on: February 03, 2011, 06:44:57 am »
DocJ:
Do you have any heat problem with oil etc???
thomas
Offline Doc J
  • GT40 - AE86C
« Reply #58 on: February 05, 2011, 09:34:43 am »
Without oil-cooler the temp of the oil is going to 115-120 deg-Celsium. An oil-cooler and plate from Golf MK1 GTI is best solution.
I'm driving only with Motul 4100 Turbolight 10W40.
Offline Thomas
« Reply #59 on: March 16, 2011, 11:12:05 am »
Just for you info.
A qiuck translation by google and some swedish words in it but you get the idea anyway.
enjoy.
Project Polo TD's 250% performance increase!
Diesel Club Sweden has decided to make two technology projects this year (2011).
An electronic project where a BMW 335d 2010 shall be maximized to the new power level.
This is done through various modifications, but with a pristine engine.
Car two, as this project is about is a Polo 1.4d 1993 model year.
This car must be set against an original car in various exercises.
The idea on this project has been to maximize the car's performance on so many levels it
goes with every step.
We shall as far as possible make all things which this entails.
The guiding principles of this project is that knowledge comes first.
Engine:
The car is std, an N / A, that is, a "vacuum" diesel-1W designation.
Then this will turbokonverteras etc we change name to 1wTD.
Manifold:
New manifold to be built where the pipe length is made equal in length.
For this to be arrange to be made, a CAD file of the flange to the engine and turbo are created.
These will then be milled out of a NC-controlled milling machine. Output for external wastegate.
This is Alverby Racing.
Pump:
If that is the bosch type will be converted to a unique pump for this car.
Internally, this pump have many items made with trådgnistningsmaskiner etc.
Flue gas limiter must be added to the pump when the old pump is not designed for turbo
applications and therefore, this part.
Goran "Diesel Meken" Lindgren in Aneby.
Spreaders / injectors:
These calibrated. Remains at 130bars opening pressure.
The cylinder head / head:
Porting and processed for optimum flow and heat transfer.
The cylinder head / head porting by Jorgen on High Performance Heads.
Camshaft:
If the opportunity arises, the camshaft ground with new angles that are better suited for
overcharging.
Intake:
Portmatching against the cylinder head, crank welded again, turbotrycksnippel added and
polishing. Jorgen on High Performance Heads
Engine Block:
Renovated up that blasted and new coating applied.
Block redrilled or drilled on the new dimension.
If technology enables an adapter ring of piano wire nerfällning so this will be done
New main bearings, etc.
Bottom Bracket exchanged, and all seals.
Pistons and rings:
These refurbished alt replaced with oversize.
Rods:
They X-rayed and ballpeening for better strength.
Intercooler:
Bmw 525TDS. If this is not enough, we will replace it.
Other:
Water pump replaced and the oil pump checked.
Cylinder head gasket is made of 1.8mm copper with std gasket as a template for details etc. are
available. Oil cooler Volvo Group A 95graders thermostat, 15raders oil cooler from the Saab 9000.
Transmission:
By default, this car is a gearbox of the type 085 with mating 8p.
When this box is a gasoline engine custom box that is the ratio of this box is not suited for
diesel. This leads to high revs and low speed.
We will replace this with a box from a golf mk3 1.6 ABU engine.
This box is called the CHL and has a better return.
We will disassemble and refurbish up the box and reinforce all the gears and shafts.
The most famous problems will be eliminated in this process.
The methodology for this is kulpeening.
The goal of this is to achieve a 30% increase overall durability.
According to the information we have in the current situation so that the box in original condition hold for
165nm.
A 30% strengthening materials, gives approximately 210nm.
This along with other reinforcements and "trick" so the box should come up to about
250Nm.
Clutch:
Std 180mm diameter and are capable of 110Nm
New access is built as per new spec. 200hkr and 280Nm.
This means 200mm dia.
We are now building a machine with these target values.
The block is calculated under the following assumptions:
The castings used have the same quality as the Volkswagen's other engines and
production facilities using the same timeframe.
This means accomplish the following:
We know that 1.6liters engine in the Golf GTD designation SB withstand a maximum cylinder pressure on
about 90-110nm. That is, most construction sites, these numbers 220-240hkr 380/420Nm boost 2 -
3.5bar.
Do we take time to add a 40% safety margin on this to remove the uncertainties as
has concluded that approximately 60Nm per cylinder should be a good limit.
60x4 = 240Nm. We, therefore, builds a machine that shells withstand generating 240Nm of the crankshaft.
The pump is built to deliver fuel, equivalent 170hkr.
When viewing the engine technical spec like this:
1wTD std 1W
170hkr/4500rpm. 48hkr/4500rpm
240nm/3000rpm 85nm/2700rpm
Bore: 75mm 75mm
Stroke: 79.1 79.1
Compression: 20.5:1 22.5:1
Boost pressure: 1.8-2.5 n / a
Turbo: Garret TB2514 465555-2/3 Plugged wastgate. n / a
How much can withstand engine and transmission?
This is where our collective thinking about any problems we will try to
prevent as much as possible in the drivetrain.
Boost pressure:
Boost pressure will be around 2bar.
Past experience has shown that the engine can handle this.
To re-create the margin so kulpeenas candlesticks etc
Surface structure AB in Arboga is project partner in this.
Heat:
What we know is that the heat will be a problem.
We must cut down this factor to its minimum.
Friction, degrees of combustion and maintaining lubricity are all things that affect.
The back pressure creates heat that is known to all activities that can reduce this to be made;
manifold with good flow, cylinder head ported cylinder head, etc ported by Jorgen at High Performance
heads. If we can not bring down the exhaust temperature "so we add a water / ethanol injection.
We have this IOM also gained a partner that can heat treat surfaces with
ceramic coating, friction deal with such molybdenum to take down the friction and create
margin against the lack of oil pressure, etc. Metalock engineer has the skills that enable
this. Metalock has been contracted to all the details where you can achieve a positive result
map this should be treated according to their expertise.
Transmission:
Sprockets, stock and house shall kulpeenas, with the goal of raising the building elsewhere.
Surface structure AB, the experience of this process and given opportunities to do what
they can be on various details.
Overall:
Contorted poses problems.
Low turns and high torque is a ödestiger combination, so the tanks have been following.
The turbo was chosen to deliver the maximum pressure at higher revs than usual in a diesel car.
We have experience on how a turbo from the Golf 1.9TD behave and this charge very
early. BMW turbo Garret 2514 is slightly bigger on the exhaust side so that the boost
moves up in the code by about 800rpm. On såsätt we have created a small margin against the maximum
load. Estimated to load the previous turbo max at 2300rpm, new turbo at
3000rpm. We should probably study the wastegate and external use.
The drive axles on this car is the most serious available to the car as std, these are likely to
keep as they are mkt common in motor sports scene in germany eg Bergcup who is back racing.
Where these axes are used because of its strength, etc, we make the same assumption here, it is.
Chassis and brakes.
At the front, is the same principle as that of "bubbles", that is to say the least weak.
You could describe it like this.
When the brakes to move the wheels Ca 2-3cm back. The entire front suspension geometry changes.
The brakes are solid discs front and drums rear, and also leave them little time.
The car wobble like an old horse trailer type, feel like you should dump / tip.
During the steering is fantastic, the car slides forward.
So what are we doing this?
The chassis in general:
Lowering the car with the help of lowering springs 80mm front and 60mm rear.
Shock absorbers replaced the custom of lowering.
Rear axle:
Wheels rear angles adjusted to-2grader camber for better grip.
Stabilizers Rear needed, so one should be presented also mounts etc for this.
If possible adjustable.
Widening ~ 20mm of rear axle.
Front axle:
Rambenen (body structure) is reinforced with the help of a subframe that connects the right side with
the left side via bolts.
Link arms are changing angles as the geometry changes, a brace with unibolts built to take care of
forces in the longitudinal direction.
Shock towers are connected by rods.
Tunnel Reinforcement included the subframe.
All this is done to succeed in maintaining the geometry.
The brake system:
New master brake cylinder 23mm instead of 20.6
Rear: Disc brakes from the Golf GTI 226mm
Brake calipers Passat 2008 aluminum integral handbrake.
Requires re-submission of the hand brake wire and sleeves to take care of the battle.
Then we want to keep the standard wire.
Front: Disc brakes from OPEL Vectra B 256mm x 20mm ventilated
Ok: Opel Vectra B 1997th
Brake Hoses from HEL
Custom stålomspunnet, one part VW Opel second, adjusted length of both front and rear.
The brake relay valve from the Passat 3b.
The widening of the rear axle and the need for wider tires and larger wheels make the body
must change. Although ET measurement is changed to about 13, std is 38. This provides a 70mm wider track.
Wheel arches the rear of the car cover over the wheel at the top, making it impossible to change
needed.
Body:
To enable this expanded body 30mm per side and wheel arch edges from Golf MK1
welded to the vehicle front and back.
Wheel wells moved up x number, etc. for better spins on deck.
The expansion is made of the same type golf rallye alt BMW's M3 (e30) plus
we add the Golf MK1 wheel arch extensions beyond this.
These are shared and plastic welded to front and rear bumpers to get a factory appearance.
The expansion is made by Martin Rosendorf in Steungsund.
Multiple winners in Vallåkra for its breadth tions and modifications of the Volvo bus bodies.
The interior:
Chairs and rear seats from PoloG40.
Glove compartment lock my console from G40
The interior sewn on with a technical nature.
The following thoughts were and were developed.
No hot and cold.
Good support in hand, but also back.
Without slipping into the chair.
Creating a good and durable surface with a respectable appearance.
Michael Thors saddlery in Trollhättan account for this.
Other sponsors and partners, etc.
Autodelar.net All material in standard form.
J.-spec.se All material in the form of gauges, brake hoses, etc.
LG-dismantling all materials needed for the development beg.
Trailer 3500 All transportation sells trailers to many different needs.
Auto Tech Ltd Funded by the coupling.
Elmo Leather Leather / leather interior for details
Plus a lot more people with specialist knowledge who is acting as a sounding board.
ny questions.
Sincerely
Thomas Knutson
Project Manager / Owner
Chairman of the Diesel Club Sweden.
0736-561196
« Last Edit: March 17, 2011, 08:28:34 am by Thomas »
