!!! URGENT HELP !!!!!! Boost return valve
Started by đuro, March 07, 2009, 05:22:15 PM
đuro
What can happen to g-lader nd engine if I put i/o original trottle totaly different trottle without boost return valve? i know the whole boost will run into engine but can I regulate boost with blow off valve?
So when I push pedal, boost will go to the ongine nd when I pull the pedal off surplus of presure will go out fm pipes through blow off valve
Can this system work on G engine?
No- you'll be trying to force air into the engine at all times.
You need the proper boost return valve, dump valves can't flow enough.
đuro
Use a GT throttle body with TPS and modify a G40 BRV to suit, shouldn't be too hard, only 2 bolts and 1 linkage.
