Author Topic: Injectors  (Read 32889 times)
  • Validating Members
Injectors
« on: February 25, 2009, 05:52:49 pm »
Fuel Injector Cleaning
With some G40s, 20 years of service is just round the corner- so it will come as no surprise that certain components will require attention/refurbishment.
Often overlooked, a healthy fuel system is a necessity before seeking more power.
Polo Performance Parts can now offer a full injector cleaning service & diagnostic report for all Bosch/Siemens style injectors.
Using the latest ASNU equipment, injectors are ultrasonically cleaned and have the following diagnosed:
1) Spray Pattern
2) Resistance
3) Flow rate at all duty cycles
4) Maximum static flow rate
If repairs are required we can also replace internal filters and pintle caps where necessary. O-Rings are replaced on every set of cleaned injectors.
£35/set (4) inc. return postage.
Injectors For Sale
Alongside cleaning/testing your injectors we also offer refurbished components which come fully cleaned & tested with new o-rings and pintle caps where necessary.
Please contact for prices, we currently have in stock:
250cc/min Bosch injectors, well matched set of four, Red in colour, fully cleaned & tested. £65 inc delivery- 2 sets available.
Offline DKnight
Re: Injectors
« Reply #1 on: February 25, 2009, 08:03:04 pm »
awesome, great price too, will be zaping mine down
what will the cost be if it requires new filters, or pintle caps?
Re: Injectors
« Reply #2 on: February 26, 2009, 07:08:56 am »
Couple of quid extra, nothing too alarming, just takes a little longer to get the filters out. I'll only replace them if the injectors need it  :)
Offline DKnight
Re: Injectors
« Reply #3 on: February 26, 2009, 09:16:32 am »
cool man no problem, i will send my set down, and i think my mate wants his doing too
pm me or msn me an address to send em to
cheers :D
Offline Robin
  • 194bhp - 1341 Turbo
Re: Injectors
« Reply #4 on: February 27, 2009, 07:29:37 pm »
might send mine to you too
Offline vwmk3jon
Re: Injectors
« Reply #5 on: February 28, 2009, 09:35:27 pm »
Red G60 injectors? makes me wonder now if the ones i have are 310cc or not!
Re: Injectors
« Reply #6 on: February 28, 2009, 10:33:25 pm »
check the part number on them against the list in the "articles" section on the main site.  Colour doesn't mean anything, you can get injectors in all sorts of flow rates that have red tops.
Re: Injectors
« Reply #7 on: March 01, 2009, 12:56:15 pm »
As Haysey says coding injectors by colour is possibly the worst thing you can do, some 'greens' are 600cc+ go by flow rate and you know where you are.
I've got some 310cc/min ones if you need them Jon- they're Yellow though  :P
Offline vwmk3jon
Re: Injectors
« Reply #8 on: March 20, 2009, 01:04:19 am »
i'm getting Phil to check the code on them for me.
Re: Injectors
« Reply #9 on: March 20, 2009, 06:38:54 am »
PM me the part # and I can do it  ;)
Re: Injectors
« Reply #10 on: March 20, 2009, 09:32:32 am »
anyone wanting to check flow rates from part codes on bosch injectors. use this table which is on the website:
http://www.polog40.co.uk/article_injector_table.php
Use the search function in your web browser (usually ctrl+f) and type the code in off your injectors with no spaces.
« Last Edit: July 15, 2010, 01:12:33 pm by hayesey »
Offline dazzle53
Re: Injectors
« Reply #11 on: August 16, 2009, 09:41:58 pm »
hi im intrested in a set of 250cc injectors
thanks
darren
Offline garye40
Re: Injectors
« Reply #12 on: August 31, 2009, 08:14:42 pm »
hey I need some 300cc injectors for a mapped chip i have also need a 250kpa map sensor if you can help cheers
Re: Injectors
« Reply #13 on: September 15, 2009, 02:51:22 pm »
Got 2 sets of 250cc injectors in stock at the moment  :)
Is it 300cc specifically that you want, or 310cc?
PM Andy Regarding a map sensor.
Thanks,
Offline dub-disaster
Re: Injectors
« Reply #14 on: July 15, 2010, 12:25:18 pm »
I'd like my injectors cleaned please, can you pm me postal address and payment details ? Thanks
