Injectors
Started by Yoof, February 25, 2009, 05:52:49 PM
Fuel Injector Cleaning
With some G40s, 20 years of service is just round the corner- so it will come as no surprise that certain components will require attention/refurbishment.
Often overlooked, a healthy fuel system is a necessity before seeking more power.
Polo Performance Parts can now offer a full injector cleaning service & diagnostic report for all Bosch/Siemens style injectors.
Using the latest ASNU equipment, injectors are ultrasonically cleaned and have the following diagnosed:
1) Spray Pattern
2) Resistance
3) Flow rate at all duty cycles
4) Maximum static flow rate
If repairs are required we can also replace internal filters and pintle caps where necessary. O-Rings are replaced on every set of cleaned injectors.
£35/set (4) inc. return postage.
Injectors For Sale
Alongside cleaning/testing your injectors we also offer refurbished components which come fully cleaned & tested with new o-rings and pintle caps where necessary.
Please contact for prices, we currently have in stock:
250cc/min Bosch injectors, well matched set of four, Red in colour, fully cleaned & tested. £65 inc delivery- 2 sets available.
DKnight
awesome, great price too, will be zaping mine down
what will the cost be if it requires new filters, or pintle caps?
Couple of quid extra, nothing too alarming, just takes a little longer to get the filters out. I'll only replace them if the injectors need it  :)
DKnight
cool man no problem, i will send my set down, and i think my mate wants his doing too
pm me or msn me an address to send em to
cheers :D
Robin
might send mine to you too
vwmk3jon
Red G60 injectors? makes me wonder now if the ones i have are 310cc or not!
check the part number on them against the list in the "articles" section on the main site.  Colour doesn't mean anything, you can get injectors in all sorts of flow rates that have red tops.
As Haysey says coding injectors by colour is possibly the worst thing you can do, some 'greens' are 600cc+ go by flow rate and you know where you are.
I've got some 310cc/min ones if you need them Jon- they're Yellow though  :P
vwmk3jon
i'm getting Phil to check the code on them for me.
PM me the part # and I can do it  ;)
anyone wanting to check flow rates from part codes on bosch injectors. use this table which is on the website:
http://www.polog40.co.uk/article_injector_table.php
Use the search function in your web browser (usually ctrl+f) and type the code in off your injectors with no spaces.
dazzle53
hi im intrested in a set of 250cc injectors
thanks
darren
garye40
hey I need some 300cc injectors for a mapped chip i have also need a 250kpa map sensor if you can help cheers
Got 2 sets of 250cc injectors in stock at the moment  :)
Is it 300cc specifically that you want, or 310cc?
PM Andy Regarding a map sensor.
Thanks,
I'd like my injectors cleaned please, can you pm me postal address and payment details ? Thanks
