Help!
Started by RichStu82, December 18, 2023, 01:17:17 AM
RichStu82
My G40 was running fine then cut out. I replaced the lift pump as it had broken. Car now won't start. Getting fuel to the fuel rail and fuel is pumping out of the return pipe on the bottom of the fuel pressure regulator when cranking which is odd.  Ignition side is spot on so it's defo a fuel issue. If I spray carb cleaner directly into throttle body it starts and runs fine briefly.
It's had a new fuel filter and in-line fuel pump recently so I'm wondering if I've put something back together wrong!
Any help would be greatly appreciated
Rich
