Golf Mk1 - Midilite - 256mm Vented Kit fit a g40
Started by chasesfc, February 03, 2009, 06:39:42 PM
chasesfc
hi
this is a front brake kit from rally design. will this kit bolt onto  a mk3 g40 setup.
Golf Mk1 - Midilite - 256mm Vented Kit  £438.90
application: Golf Mk1 - Please Specify 76mm or 94mm Lug Mounts
Caliper Type: Midilite
Lug/Radial: R
Disc Size (Diam x Width): 256 x 20
Possible Wheelsize (Inches): 14
Spare Disc Part No.: 500-0017A
cheers marc
yes it's what I've got on my g40.  Although the caliper brackets do mean you have to cut a small amount of metal off the strut housing though.
chasesfc
ok cool buddy.
what are they like ? worth the price tag
I find them good on track.  Not sure it's worth the expense on the road though.
chasesfc
well im building my g40 with track days in mind so i think i will get a set. what brake hoses do you run or can you run standard polo hoses with these. ?
standard ones are a bit too short, I think mk2 golf ones would be the ones to use.  I do have standard ones on mine (as I'd already bought them) but I made a short solid connecting piece and bracket for them so they reach.
jez1272gt
Cant say ive driven them yet but they will be worth the extra pennies. Dont forget the price of this kit excludes pads so you will need to budget for these as well. With mine, like Hayesey i have removed some material from the hub housing and a little from the back of the mounting bracket to get them to fit. One side needing more material removing than the other but be carefulll not to take too much back on the strut housing as you will start to get close to the weld..
indeed.  Other things I'd say is put a load of copper grease into the bolt heads on both the bracket and caliper bolts as they will rust pretty quickly otherwise.  I also put locktight onto the bolts so they don't loosen as they will be pretty highly stressed!
polo classic
How would you rate this kit against the OEM Audi/Scirocco 256mm setup?
well having had a go in yoofs car once with his audi 256mm setup I'd say the pedal feel is much more solid on the 4pots.
