Ignition timing
Started by Husb0009, December 03, 2021, 07:32:47 PM
Husb0009
I have a polo g40 on a PY engine code and it has a toothed supercharger belt. The thing is I carnt seen to find a timing mark on the crank pully. So my question is, is there any other way to set the base timing on the engine. Having some running issues and trying to rule put timing
Thanks in advance
Hi, are you sure there's no markings on the side of the pulley? I know when I used to have toothed belt, the pulley had the timing marks on the side of it. It was really hard to see them from the top, I used a paint pen to mark the teeth on the pulley the marks lined up with.
Failing that, you'll need to remove the spark plug from cylinder 1 (the end where the belts are) and find top dead centre yourself using ideally a dial gauge with an extension piece poking through the hole onto the top of the piston, turn the engine by hand using a 19mm socket on the crank pulley until you get the piston to the highest point. If you don't have a dial gauge and/or don't have a long enough extension for it, then you can try with a long screwdriver down the spark plug hole resting on top of the piston (don't put any weight on it) and feel for the highest point, not very accurate but it does work and will probably get you to the right tooth on the timing belt if you are careful.
get a temp sender from VW, I wouldn't bother with any aftermarket ones.
