Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Engine and Transmission
Clutch lever spring
« previous
next »
Pages: [
1
Go Down
Author
Topic: Clutch lever spring (Read 1429 times)
Agent47
Clutch lever spring
on:
September 22, 2019, 09:53:20 pm »
How important is the clutch lever spring on top of the gearbox? Mine appears to have gone missing in the years between being taken off, rebuilt, and being out back in.
In a completely unrelated note, anyone got a spare clutch lever spring?
Caskill
Re: Clutch lever spring
Reply #1 on:
September 24, 2019, 12:19:49 pm »
Is it the spring that's part of the clutch cable your needing? I should probably have an old cable with one if you need it. I'm pretty sure the sprung fingers on the pressure plate should do a good enough job of returning the lever once the engine and box are bolted up
Agent47
Reply #2 on:
September 25, 2019, 07:49:24 pm »
No, it's the spring in top and outside of the gearbox. It's on the same lever as the clutch cable, but is just a spring.
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
Clutch lever spring
