G40 won't start/turn over
Started by lectrotek, January 26, 2019, 11:54:32 AM
lectrotek
Hi all,
Came out the other day to give the G a blast after a couple of days standing and it's completely dead.
Dashboard lights/radio/headlights all come on but no turn over. Not even a solenoid click
I can also hear an electrical motor sound toward the rear which i presume is the fuel pump.
I don't think it's the battery as all the electrics work and i've tried jumping it with a battery pack.
Anyone got a clue what might be up? My mechanic skills are a work in progress so it's all a learning curve!
vwmk3jon
Dash lights go out when you try to crank it? If they do your batteries died. Common issue in the cold weather.
Check both relays next to the ECU as well as the big yellow fuse just incase.
