G40 engine.
Started by vwmk3jon, December 22, 2018, 06:49:13 PM
vwmk3jon
Selling my spare engine as I doubt I'll be needing it.
1341 accralite pistons
268/268 camshaft
Vernier pulley
Baffled sump with oil return
315cc red injectors
51mm throttlebody with 6psi switch
Rothe manifold
K03 turbo - 0 miles
PSD downpipe
Forge actuator
Oil feed and return pipe
Water feed pipes.
Metal boost pipe
Random silicone boost pipes
Powdercoated rocker cover (ok condition)
8p gearbox
PPP chip & uprated map sensor in ecu.
Full engine loom
£1500
hey pauley
Afternoon. Where bouts in lincs are you? Are all the bits built up? Have you had the engine running on this set up.
vwmk3jon
I'm just outside Spalding.
Engines still currently 90% built. Turbo, manifold and downpipe have been removed but still present.
Camshaft and dizzy have been sold so open to sensible offers on the remaining parts.
I have had the engine running in this spec for 40k miles.
vwmk3jon
SOLD...
Admin please lock.
