Author Topic: G40 rose joint arms wanted  (Read 2754 times)
Offline ereeiz
« on: May 08, 2018, 04:24:54 pm »
Anyone got a pair? Don't care about the rubber bush, that will be upgraded to poly. As long as the rose joint is still intact and working.
I want to fit them this weekend so please reply / PM me with how much you want inc. P&P.
I can paypal you straight away (generally check my mail every hour or two in the week).
Thanks.
Offline Mark Millington
Re: G40 rose joint arms wanted
« Reply #1 on: May 08, 2018, 04:34:16 pm »
Sorry if I'm being naive but what's the difference I was looking at some tca s to replace mine on auto doc are the ones with rubber either end no good for a g40?
Offline ereeiz
« Reply #2 on: May 08, 2018, 06:45:09 pm »
The G40 has a rose joint on the inner part and a rubber bush on the outer. All others are rubber bushes both ends. They will fit and work fine but if you're looking to make the car a bit sharper and less wooly then G40 ones are best as the rose joint just rotates, the bush can allow movement in any direction.
New G40 ones are about £130 from maxrpm.de
« Reply #3 on: May 09, 2018, 07:32:24 am »
I've a very very good, low mileage set of bottom g40 arms.  Pm me an offer.
« Reply #4 on: May 10, 2018, 06:07:53 pm »
Just sourced 2 myself from the Portuguese facebook page 30 pound each rose tinted vw items have a look a guy called Miguel has sent me loads of stuff from orginial air boxes to these arms injectors etc all fairly reasonable prices
