Author Topic: Spark plugs - Anyone used Bosch WR 56?  (Read 4566 times)
Offline ereeiz
« on: May 01, 2018, 02:28:23 pm »
I was looking about for a cheap Haynes manual, ended up on their site and noticed as I was browsing through the examples of the content in the manual that it states to use a bosch WR 56 plug for a PY (G40) engine. Anyone ever heard of this before?
Is that a new plug?
I can't remember the ins and outs of plug codes.
The reason I ask is they're £3.50 each. A damn site cheaper than W5DPO's at about £15 each!
*edit* I've emailed Bosch enquiring about this. I'll update when they reply.
« Last Edit: May 01, 2018, 03:02:04 pm by ereeiz »
Offline ereeiz
Re: Spark plugs - Anyone used Bosch WR 56?
« Reply #1 on: May 01, 2018, 03:24:03 pm »
Spent a bit longer looking about on various Bosch sites and came across a list of everything they make for a G40;
http://www.bosch-automotive-catalog.com/en/internet/ECAT-RS/vehicle-info/-/vehicle/equip/VWW/986/as2p4bulrf591csfrpeec32hr1ujjpna
Long story short, it states W5DPO;
Spark plug, Double platinum (W 5 DP 0)   0,70 mm Electrode gap   0 241 247 500
Offline ereeiz
« Reply #2 on: May 01, 2018, 03:26:28 pm »
Bosch W5DPO spark plug specifications;
Type formula   Spark plug, Double platinum
Thread diameter   14 mm
Center electrode core material   NiY+Cu+Pt
Electrode gap   0,60 mm
Interfer. supp./burn-off res.   0 kOhm
Spark position   3 mm
Search number (KSN)   W5DP0
Marketing number   W5DP0
Type formula   W 5 DP 0
Ground electrode material   NiY+Pt
Type formula (old)   W 235 P 21
Tightening angle   90 °
Centre electrode   0,8 mm
Thread pitch   1,25 mm
Thread length   19,0 mm
Production discontinuation   -
Number of ground electrodes   1
Sealing seat   flat-mouldable
Center electrode material   Pt
Type of connection   DIN/SAE nut included
Independent aftermarket part (IAM)   0241247500
Designation   Spark plug, Double platinum
Width across flats   20,8 mm
Tightening torque   28 Nm
Offline ereeiz
« Reply #3 on: May 01, 2018, 03:31:01 pm »
Bosch WR56 Spark plug specifications;
Type formula   Spark-plug set, Super 4
Center electrode core material   CrNi+Cu
Electrode gap   0,90 mm
Interfer. supp./burn-off res.   6 kOhm
Spark position   4 mm
Search number (KSN)   507
Marketing number   507
Type formula   WR 56
Ground electrode material   CrNi
Article status   Discontinued item
Centre electrode   2,4 mm
Production discontinuation   10/2017
Number of ground electrodes   4
Center electrode material   CrNi
Type of connection   Detachable DIN/SAE nut
Independent aftermarket part (IAM)   0242242802
Designation   Spark-plug set, Super 4
Offline polo classic
« Reply #4 on: May 02, 2018, 09:28:40 am »
I have tried WR56
they didn't work at all
lots of missfires
Offline ereeiz
« Reply #5 on: May 02, 2018, 03:18:18 pm »
Boooooo. I was hoping it was going to be a new source of cheap plugs.
thanks for letting me know, I'll inform them when they reply!
Offline nikolakiss0104
« Reply #6 on: May 02, 2018, 08:43:48 pm »
my haynes manual have the champion N6BYC spark plug
« Reply #7 on: May 04, 2018, 09:23:27 am »
most people use ngk due their affordability
Offline ereeiz
« Reply #8 on: May 04, 2018, 10:30:29 am »
I thought nothing worked except W5DPO's due to....... whatever bit of witchcraft it is that only makes W5DPO's work?
Could you tell me which specific NGK plug works please Pete?
Anyone else with working plugs feel free to pipe up with what has worked for you too!
Thanks.
Offline grungeisdead
« Reply #9 on: May 04, 2018, 01:09:21 pm »
ngk bpr7eix is the w5dpo equiv.
some people run w4dpo which are slightly colder, if you are running higher boost.
Never had any issues with ngk's. When I melted a piston I was running w5's but wasn't running meth injection which is probably why I detted the engine
« Reply #10 on: May 04, 2018, 01:16:15 pm »
this haynes manual states Champion NGBYC of which I can't find on the net.
http://www.volkspage.net/technik/manuaisecatalogos/02/haynesrepairmanual_polo86c90to94.pdf
Looking at the spec differences between W5DPO's and WR56, I'm not surprised it made a PY run like a bag of shite
