Plastic timing pin?
Started by Ross36, April 20, 2018, 07:15:20 AM
Ross36
I have a 1994 G40, it doesn't have the metal timing pin.
It seems to have a plastic one?
Though it looks like it has broken, I can't find any reference photos to see where the timing mark should be.
Seen anything like this before?
Silver pen is where the mark on the crank lines up to.
https://flic.kr/p/GFVcEa
https://flic.kr/p/23A27VC
https://flic.kr/p/26hc8zQ
Ross36
Found this searching the part number for a lower cover, every photo I've seen of a G40 has a metal timing pin like the last image.
https://flic.kr/p/23A8asu
https://flic.kr/p/JdhKg7
https://flic.kr/p/23A8yLJ
plastic timing cover with pointer is a later replacement part...   (easier to replace that one with a cut out for metal pointer when in situ)
Ross36
For now since I've only got part of it, do you know if it's timed to the vertical part or horizontal edge?
_|_
