Max RPM Windage Tray
Started by Yoof, March 15, 2018, 10:04:12 AM
New unused Max RPM Windage tray – will do it for £30 delivered to Mainland UK
ereeiz
Have you had a go with one?
Is it likely to stop the oil light coming on round roundabouts? I've not driven mine in a few years but always had that issue with every G40 I've had, and normal corners too when going quick.
Thinking about it, I've got it mixed up wth a baffled sump. This is for oil/crank separation isn't it?
Agent47
Sold I'm afraid chaps.
Grahame - Yes correct if you're experiencing oil starvation due to lateral loads (cornering) a baffled sump is what you need (or less grip!) Windage trays control the oil vertically, with the aim of reducing parasitic losses by not allowing oil to hit the crank.
