As Haysey said, they come oiled when new, the oil is there to help trap smaller particles. It probably helps the fibres in the filter stay supple too, extending its life.
A bit of a shit analogy here, but get a sieve and drop flour through it. It falls through. If you spray the sieve with oil so it has a film on it, then repeat the same test, a lot less flour will get through as it gets trapped in the oil.
Obviously, that's a super simplified version of what the filter oil on a filter does, but in a nutshell, that's it!
Make sure when cleaning it you do it inside out as much as possible. I.e. blow air through it from the inside out. Blowing from the outside in can push stuff further into the mesh, making it harder to get out. Same when rinsing it.
As long as it's air filter oil you're putting on it should be fine. If you want to be double sure take a look at the air filter manufacturers website and the same for the oil. There'll probably be some minimum spec. listed or something to match one to the other.
