Author Topic: Few parts that need gone  (Read 4235 times)
Offline Jezza-7
« on: May 05, 2017, 12:38:36 pm »
All prices do not include postage
I have 2 G40 looms,
1 is £80 and was removed from my G40. All good and working condition. One plug was replaced on the blue temp that PPP sell. Sold
1 is £40, this was from a mates LHD G40 and was all good. The small fuse thats built in was missing but i found one from a friend who was breaking a polo, so i got that off him and put it into the loom. It should be absolutely fine but i have no way of testing to confirm, hence the price. Sold
1 G40 ISV £25 Sold
1 G40 knock sensor £20
1 G40 Airbox to charger pipe £20
1 Ash tray with cigarette lighter £10
1 Engine mount for non g lader £10 Sold
1 Rad plastic top cover non G40 as it came off a standard polo £10 (in pic with compensator)
2 G40 ECU metal brackets £10 each
1 G40 fuel rail with the main plug missing ( i had to rob it) can easily be sorted out £10
1 G40 fuel rail all complete and working £20 Sold
1 Cambelt outer cover £15
1 G40 rear exhaust hangar that comes off the back of the block £10
1 Blower unit, doesn’t have the inlet connection with the bleed £15
1 Standard G40 rad fan £15
1 Rear axle brake compensator, this was replaced 5 years ago so fairly new and clean still, comes with spring and both brackets £20 Sold
1 pair of steering arms. Very little use and great condition. £40
Finally a set of Genuine G40 head bolts. These are obsolete and these are brand new still in original box. £60
« Last Edit: May 16, 2017, 04:03:35 pm by Jezza-7 »
Offline quiksilver_jake
Re: Few parts that need gone
« Reply #1 on: May 05, 2017, 07:36:27 pm »
Is the brake compensator  aftermarket or oem?
« Last Edit: May 05, 2017, 08:02:12 pm by quiksilver_jake »
Offline Jezza-7
« Reply #2 on: May 06, 2017, 11:10:49 am »
I will have a look.
Offline Jezza-7
« Reply #3 on: May 07, 2017, 09:14:11 pm »
Jake, there is a marking on the compensator but looks like it might be meyle maybe? Its also got DE stamped so must be a german part.
Engine mount and 1st Engine loom are sold!
« Reply #4 on: May 07, 2017, 09:43:25 pm »
OK, what about £20 posted?
Offline Jezza-7
« Reply #5 on: May 08, 2017, 10:35:30 am »
Yeah mate thats fine mate.
I’ll pm you.
« Reply #6 on: May 08, 2017, 12:04:44 pm »
Sent  :)
Offline Jezza-7
« Reply #7 on: May 16, 2017, 04:04:00 pm »
Updated.
