Author Topic: timing up procedure  (Read 5834 times)
Offline supercharged spaniel
  • GRRRRRRR
timing up procedure
« on: April 11, 2008, 10:51:17 am »
i will have a timing light tomorrow and im going to check the ignition timing.  what im unsure about is the exact procedure, as in... do you unplug the blue temp sensor?  is there something like that that has to be done?
thanks...yet again...
dan
Offline giorgio
Re: timing up procedure
« Reply #1 on: April 11, 2008, 01:16:55 pm »
dan after we spoke I read into this as I am doing it on my the G's on saturday.
Get the car at normal operating temp then turn it off.
Unplug the hall sender
Manually turn the crank pulley until you line up the timing marks
Reconect the plug and connect the light to Cyl1.
Then your good to go
When you do this make sure all the electrics etc are turned off.
And make sure you mark the dizzy timing before you start so you can always go back if it goes horribly wrong
  • GRRRRRRR
Re: Re: timing up procedure
« Reply #2 on: April 11, 2008, 03:52:10 pm »
[quote pid=806 author=giorgio date=1207916215]dan after we spoke I read into this as I am doing it on my the G's on saturday.
And make sure you mark the dizzy timing before you start so you can always go back if it goes horribly wrong[/quote]
ok thanks for that.  why do you need to unplug the hall sender?
Offline giorgio
Re: Re: Re: timing up procedure
« Reply #3 on: April 11, 2008, 04:10:30 pm »
[quote pid=811 author=supercharged spaniel date=1207925530][quote pid=806 author=giorgio date=1207916215]dan after
ok thanks for that.  why do you need to unplug the hall sender?[/quote]
according to the haynes its to disconnect the engine.
Maybe it still measures when the ignition is off. Maybe for when you turn the car off but the engine still turns over for a second.
Over to those who know............
Re: Re: Re: Re: timing up procedure
« Reply #4 on: April 11, 2008, 04:23:09 pm »
you unplug the blue temp sender with the engine running and up to temp to put the ecu into service mode.  You do this when setting the ignition timing or idle screw.  I would have thought the engine would cut out as soon as the hall sender was disconnected!
Make sure you plug the blue temp back in once you've done before turning the engine off.
  • GRRRRRRR
Re: Re: Re: Re: Re: timing up procedure
« Reply #5 on: April 11, 2008, 06:07:40 pm »
[quote pid=814 author=hayesey date=1207927389]you unplug the blue temp sender with the engine running and up to temp to put the ecu into service mode.  You do this when setting the ignition timing or idle screw.  I would have thought the engine would cut out as soon as the hall sender was disconnected!
Make sure you plug the blue temp back in once you've done before turning the engine off.[/quote]
this is the procedure i thought was right ^^^  thanks for that.  anyone else?
Offline giorgio
Re: Re: Re: Re: Re: Re: timing up procedure
« Reply #6 on: April 11, 2008, 06:44:57 pm »
why does the haynes book of lies not mention this at all?
Re: Re: Re: Re: Re: Re: Re: timing up procedure
« Reply #7 on: April 11, 2008, 09:09:39 pm »
[quote pid=816 author=giorgio date=1207935897]why does the haynes book of lies not mention this at all?[/quote]
the answer is in the question  ;)
Offline giorgio
Re: Re: Re: Re: Re: Re: Re: Re: timing up procedure
« Reply #8 on: April 11, 2008, 09:17:35 pm »
[quote pid=819 author=hayesey date=1207944579][quote pid=816 author=giorgio date=1207935897]why does the haynes book of lies not mention this at all?[/quote]
the answer is in the question  ;)[/quote]
I know it often tells you the most odd ways to do things but to completely omit a pretty major part of the proceduce just seems wrong.
Whats all this hall sender jazz about then
  • GRRRRRRR
Re: Re: Re: Re: Re: Re: Re: Re: Re: timing up procedure
« Reply #9 on: April 11, 2008, 10:54:46 pm »
[quote pid=820 author=giorgio date=1207945055][quote pid=819 author=hayesey date=1207944579][quote pid=816 author=giorgio date=1207935897]why does the haynes book of lies not mention this at all?[/quote]
Whats all this hall sender jazz about then[/quote]
well the car wont run without the hall sender plugged in so i have no idea what its banging on about lol
