Timing
Started by matthg40, February 22, 2017, 09:01:02 PM
matthg40
I've changed the distributor on my g40 so I marked where the old one sat etc.ive set both timing marks up started the car up and it's misfiring like a trooper.i never had this problem last time I changed the distrubitor unit any ideas what could of gone wrong anyone?
Martyng40
I had a similar problem the other week when trying to get mines running... turns out I'd put the dizzy on 180' out.... easy fix and solved my issue
matthg40
That was the first thing I tried the firing order is 1.3.4.2 but thanks for the heads up it's much appreciated
ereeiz
Checked it's TDC correctly when timing it?
I get a long clean screwdriver, take no1 plug out and turn by hand until I get to the top of the stroke. I never trust the timing marks on the pulley as I can never remember if you time it to 0 or 1 and if it's when the engine is running or not, etc.
If it's running then you're somewhere close at least! Maybe a tooth or two out?
Tried twisting your dizxy back/ forth to alter the timing? Or even better, if you have a timing gun, use that! ;) I got mine form Halfords about 15 years ago for about £15. You'll only use it once every few years but well worth having to quickly diagnose things.
EDIT *I think you need to be in service mode to check the timing with a gun actually, so may be hard to do if you can't get it up to temp*
matthg40
Still having trouble getting it to run perfect I've set the timing with the screwdriver down cylinder number 1 trick.i know don't know what position to start the distrubitor unit before adjusting with the timing light to get it lined up with the z mark on the crank pulley.any one with any advice
ereeiz
Take a look at that link, look at each pic and read it through, maybe you missed Something?
matthg40
I'm still having trouble here the car ticks over perfect but as soon as I take it out for a drive it has zero go at all.it has no pull no boost and sounds like it's misfiring still.ive gone off the timing marks and even put a screwdriver down cylinder number 1.its lined up to the o then moved to the z with a timing light and still it refuses to drive properly.how can changing a distrubitor cause me so much trouble.please someone help me with this dilemma
matthg40
#8
I have the leads 1 3. 4. 2. 1 facing the radiator and 4 facing the bulkhead and 2 at the top As I keep reading different things
