Engine randomly cut out
Started by matthg40, February 04, 2017, 01:03:12 PM
matthg40
I was driving my g40 on the a47 and it suddenly lost all power and cut out and I'm now sat at the side of the road and it turns over but won't start.i didn't get any warning it was going to cut out my gauges were all reading the correct readings I'm now wondering what caused it to cut out.does any body have any suggestions for me.
nikolakiss0104
kwijibo_coupe
First thing that comes to mind is the coil. They can just go, was your rev counter playing up at all did you notice?
Also check all the engine earths, these engine can be fussy about poor earth connections.
matthg40
Replaced coil last week,I've just took main earth to battary,supercharger earth and coil earth off cleaned them all up and it still doesn't turn over.engine rotates but will not turn over sadly
matthg40
Just had the dizzy off and there's all bits of broken plastic inside the dizzy cap and it's full of oil and dirt aswell.i can't quite decide what's broken my heads saying it's the hall sender do people agree?or does anyone have any other suggestions.
I would of said hall sender straight away as my g40 did the same thing to me.
I might have a spare one if needed.
ereeiz
Hall sender by the sounds of it. The oil has probably weeped in from the camshaft, there's a seal there you can replace (from memory). someone on here is/was selling hall sender/ dizzy bits, take a look in the ads section!
