Coilovers (SOLD)
Gearbox (SOLD)
CAE SHIFTER (SOLD)
PPP STAGE 3 SUBFRAME (SOLD )
FIBREGLASS BONNET + WINGS £250
Driveshaft's including uprated thicker shaft. (SOLD)]
Front headlights Tinted black insides Inc side repeaters £30+postage
Debadged grill including G40 badge £25+Postage
Rear Brace (SOLD)
rear beam with custom anti rollbar and Gladdersite bushes, all freshly painted, with adjustable drop links. £250
Rear lamps late spec, 2x passenger 1x driverside £30+postage
Standard engine, includes cam, head, block, crank, pistons (not in block) oil pump, Turbo Sump etc (SOLD)
Compomotive Magnesium centrelock turbo's X5 these are unbelievably rare (only know set in 13'' left) built with brand new lips, 2x new barrels on the rear set, faces have been tested stipped coated professionaly, fitted up with brand new toyo R888 225/45 R13's and brand new centrelock adaptors, with brand new garage midnight stud adaptors. 5th wheel is just a face does come with 3 spare barrels no extra lips £2500
G40 Clocks (SOLD)
Madin Wheels 13x8 13x10.5 also has brand new lips and centres have been painted, re-drilled to 4x100 with vw centre bore (needs bolts) £550 posted
Brand New Hi-spec 6pot front brakes, these were made to fit behind the compomotive's, for the biggest brakes I could get, the have 2 piece 280mm floating disc's, with carbon pads £1100 posted
I will get the full spec of the engine loaded up in the week.
