wheel measurements
Started by chasesfc, January 13, 2009, 06:32:02 PM
chasesfc
hi
does anyone know the pcb/ offset / et of a bbs 5.5 13 inch standard g40 wheel off the top of there heads.
need some info for a wheel company im dealing with
cheers
marc
breadman
Standard wheels are 4 x 100mm PCD with an offset of ET 38. Centre bore is 59.1mm IIRC?
Max
Centre bore is 57.1mm, close  :P
breadman
#3
Doh, 2mm out  ::)
Well I knew it was a round hole if that helps?  ;D
