Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Technical
Chassis & Braking
play in steeringwheel - steering column
« previous
next »
Pages: [
1
Go Down
Author
Topic: play in steeringwheel - steering column (Read 3460 times)
Jacque
on:
May 10, 2016, 11:04:24 am »
Hi,
I got a fair bit of play in my new G's steering wheel. (all directions: left, right, under, up)
Removed the plastic under the steeringwheel to check out what is causing it and it looks like its the part where u insert your ignitionkey. the steering column? nr 14 on etka?
http://etka.cc/vw/part_single/catalog/vw/markt/RDW/modell/PO/year/1991/drive_standart/120/hg_ug/419/subcategory/34000/part_id/3690722/lang/e
i don't think its a loose bolt or something like that...
anyone have expierienced similar problems? how did you fix it? because it looks like the part is obsolete since 2012 and can't seem to find anyone offering new ones?
greets
Jacque
Re: play in steeringwheel - steering column
Reply #1 on:
May 11, 2016, 08:18:15 am »
found a second hand one. will collect this weekend
not sure if the lock is removable? so i dont have to use 2 keys...
gofasterpinch
Reply #2 on:
September 01, 2016, 02:44:49 pm »
You can remove / replace the barrel, there is a location you have to drill out with a 6mm drill - the details are in the haynes manual
Jacque
Reply #3 on:
September 09, 2016, 12:29:25 pm »
indeed, found it in haynes.
play is gone!
Pages: [
1
Go Up
« previous
next »
Technical
Chassis & Braking
