G40 adjustable TCA
Started by 642855659, April 30, 2016, 09:51:39 PM
I`m in the process of putting my G40 back on the road after a few years parked up, I`ve noticed the lower ball joint rubber is split. I`ve read previous threads about the G40 TCA`s and I don't think mine are standard, mine are fabricated with Metal inner rose joints, I`ve had the car since 1999 and can`t remember changing them, just wondered if any knew whose make they are (if any).
There is quite a lot of surface rust on them, so I`ll strip them down and see if I can get the rose joints replaced , if I can I a can replace the rubber on the ball joint
from what I can see under all that rust (wow!), they are standard off the shelf rose joints.  You can buy them at any motorsport parts place.  In the UK, places like Rally Design.
642855659
