im dabbling with the idea...again... to sell up. im tempted to get a lupo gti but to get some idea of money i need a rough guesstimate on what my g40 is worth to decide wether its worth selling or just keeping. im not asking for your opinion as to me selling or not LOL just how much you think is a reasonable price considering the following and the current market. ideas on wether to sell the plate seperatly or not? i may keep it like i said i just need a rough guide as to what its worth, to see what i can afford to do.
Make:volkswagen
Model:polo g40
Year/Reg:1992 original plate J987TPY
Mileage:135k
MOT:january 2009
Tax:end of august 2008
Good points:original G40 in white. original wheels fog lamps, tilt slide steel sunroof etc.
thatcham Cat 1 alrm immobiliser
golf rear door handles without key holes with armour door plates
only mods are:
H&R cup kit
polished rocker cover
new braided charger oil feed
Gladersiete roll bar thingys
PSD braided brake lines
Vag de-ct pipe
Full blend charger rebuilt 8k ago.
gearbox rebuilt
fan switch mounted in blank in the dash using a rear screen switch fitted professionally
this is gonna be long but in my ownership, 34k its had the following:
95% from VAG or if not they are the same items as vag would provide i.e. bosch.
fuel pumps (both)
injectors
fuel tank (waxoyled)
hall sender
coil
vacuum hoses
new shells and bolts bottom end
head rebuilt with new valve stem oil seals
head bolts
waterpump
timing belt
thermostat housing and associated parts
new oil seals and gaskets everywhere, head/rocker/cam/crank etc etc
knock sensor
lambda probe
blue temp sensor
black temp sensor
oil dipstick
earth leads
ignition leads
dizzy cap
rotor arm
battery
air filter
clucth kit
clutch cable
boost pipe jubileee clips/nuts bolts/ everywhere
brake lines replaced at last mot with genuine plastic coated steel vag ones
g12 coolant
radiator
fan switch
oil changed every 3k miles without fail
vag exhaust mounts and rubbers
mid section is almost new vag.
charger belts
discs
pads (last summer)
full brake fluid change MOT time
engine mounts
rear wheel bearings rear shoes
vag rose jointed steering arms (both sides)
the following parts have been powder coated
fuel pump bracket (fitted with new rubbers and bolts from VAG)
charger mount
rear engine mount
tunnel brace
Interior.
original apart from steering wheel which is an italvalanti one.
seats rebuilt with new cables and runners
slight fading on rear seats but no broken cables, rips or tears or damaged sponge whatsoever!
audi tt cover on clutch and brake and the original throttle powder coated satin black.
vag mats
new leather gear gaitor
no radio equiptment just a vag stereo storage compartment
gearbox rebuilt by JP race about 6k ago with new bearings and seals and refitted with new vag release bearing and vag gearbox oil.
The car is mechanically spot on. it has a slight miss fire on morning start up but drives really really well, actually i dont know why i want to sell. I will not sell the car until this sorted and am 90% sure as to what this is so lets presume this is out of the question as it will be sorted.
I am a complete fanny about this car, any amount of money is spent to keep it right!
i have a wallet of all the reciepts which i dare not count up
Bad points:back box is non genuine g40 and will probably only last another year
the body work
im going to be more critical than necessasy.
the worst is the boot, its rotten on the inside and will need replacing but the car will come with a black tailgate which has absolutly no rust whatsoever which ive been storing.
the rear corner pices below the lights have started to rust and need sorting. there is a couple of small dings (minor)
there are a few small bits here and there. but the car overall is structurally great and to make it totally mint needs a good strip down a full shoot and putting back together. the body itsself is solid! the sills are great! (nobody is allowed to touch them with a jack!)
the main bits that need sorting are replaceable panels. but the car will come with 2 new unfitted vag wings which is doesnt really need, a boot, a passenger door. ALL TOTALLY RUST FREE!!
and a boot lid vinyl! unfitted!
I cant think of anything else to say, this is one amazing G40 it just needs someone to finish the body work off and it will be even more amazing!! doesn't leak anything whatsoever! as far as im convinced its had all the money spent in the right places it just needs some one to detail it!
i wont sell the car to anyone this is my baby, if i think for a second your gonna fuck it up i'll tell you and you wont buy it! that sounds harsh but i can afford to do that!
Pictures:loads of pics of everything ive mentioned some are from last summer but its pretty much how it looks when its cleaned up!
Price:your recommendation boys.
Contact details:
