Charger belts
Started by nikferal, March 23, 2016, 10:10:46 PM
nikferal
Looking for a standard set of belts for the pulley and timing for the engine swap.
I've got a toothed pulley set but as the charger has just been serviced, I want to wear it in first before putting the kit on and ppp chip
I have a set  of stock pullies  and can also supply either new or used v belts
nikferal
cheers Pete, managed to get one already, but also need the boost return pipe, flying saucer purge valve and gauze strainer in the intercooler.
The mounting bracket off the top and the fixings at the bottom of the intercooler.
Plastic air scoop off the front.
