Turbo advice for 1W
Started by benh999, December 09, 2015, 09:01:39 PM
benh999
Folks.
Just a bit of advice, should I choose to go away from the supercharger and venture into turbo territory bearing in mind I will be using a 1w diesel bottom end and then capacity will be just shy of 1500cc what turbo can I use on her?
I will prob just use the ko3 turbo however I just wondered with the extra capacity can I go up to ko4 and if so which ko4 specific turbo will I need?
Ben :)
scully
What gearbox will you be using?
benh999
youngprodigys
What about somewhere in the middle? Ko3s turbo has a slightly bigger compressor wheel and should be able to flow the increased capacity your engine will have without the lag of the Ko4
Alexiskayak_7
Gt2554 or a gt2560 at 1.5 bar should be nice
benh999
Quote from: Alexiskayak_7 on December 10, 2015, 01:19:06 PM
Would have to fit direct on to a Rothe manifold?
samg40
Was a fast car with that engine as well!
benh999
Quote from: youngprodigys on December 10, 2015, 08:09:48 AM
Not sure they made the ko3s that is compatible with the Rothe manifold??
youngprodigys
only the compressor side differs iirc. so it would be a case of getting a ko3s compressor fitted to a ko3 hot side.
polo classic
I think I will go for a K04-15 eventually for mine, as thats about the most you can get a away with and still have half decent reliabilty with a 085 box
youngprodigys
Numbers coming out of ko4 turbo'd G40 motors are not very good. All the lag with no substantial increase in power.
GT2554R – shit your rods and cogs everywhere for the win!
polo classic
Quote from: youngprodigys on December 17, 2015, 09:52:46 AM
My mate had 1 bar @ 2000 rpm with ported head, rothe manifold and K04-15 at standard capacity
I don't think my big valve 1473 will struggle with lag...
