Author Topic: Strengthened engine bay pictures  (Read 4306 times)
Offline Alexiskayak_7
« on: October 25, 2015, 01:05:45 pm »
Hello guys,
I am in the process of getting out my engine and box, to strenght my engine bay.
Can you share please any ideas or pictures on how to strenght it?
Offline breadman
Re: Strengthened engine bay pictures
« Reply #1 on: October 25, 2015, 02:34:19 pm »
I've stitch welded the join between the chassis legs and inner wings. I've also welded around the front gearbox mount area. The most important bit though is the lower bulkhead to chassis rail joints, a notoriously weak spot that is prone to cracks and splits particularly on mk2f models. I've formed diagonal gussets here from 2mm thick sheet and welded them in.
Sorry, I'm no good with pics, but I hope this helps.
Offline Craig g
« Reply #2 on: October 25, 2015, 03:26:41 pm »
Go on the chassis faq there's a whole guide with plenty of pictures
Offline sleag40
  • Poloist
« Reply #3 on: October 25, 2015, 08:45:38 pm »
« Reply #4 on: October 27, 2015, 02:08:50 pm »
Breadman,
Can you share one picture of what you've done. Post it even if its low quality.
Offline Dipesh
« Reply #5 on: February 09, 2016, 10:47:15 am »
Do you guys weld anything under the gusset at all?
I know when the sealant is stripped back there can be quite a big gap under there, unsure if welding it is the right thing to do or not.
