Author Topic: New G40 Maps- In Stock!!  (Read 80810 times)
Offline vwmk3jon
Re: New G40 Maps- In Stock!!
« Reply #75 on: April 03, 2011, 08:06:21 pm »
Done ;)
Offline youngprodigys
  • G 3URO
« Reply #76 on: August 30, 2011, 07:29:55 am »
all the turbo maps are for 1341, do you have 1272 maps?
Offline josé
« Reply #77 on: September 16, 2011, 01:45:27 pm »
can i have payment details for a base map for my g40 turbo conversion please??
i have pm'd you both regarding this
thanks josh
  • Validating Members
« Reply #78 on: September 16, 2011, 04:14:10 pm »
Yo Josh- email was with you alst week about it dude, payapl: enquiries@poloperformanceparts.co.uk
Offline josé
« Reply #79 on: September 16, 2011, 06:04:00 pm »
i never received an e-mail from you for some reason,
i've just paid for the base map  :)
i'll pm you my address to send it to.
thanks josh
Offline dub-disaster
« Reply #80 on: September 16, 2011, 07:33:36 pm »
im after a custom map at the next availible free date please
« Reply #81 on: September 16, 2011, 08:01:29 pm »
Yep, there are several 'flavours' of most of our advertised maps.  ;)
Offline josé
« Reply #82 on: October 01, 2011, 01:55:49 pm »
hi guys,
Any ideas when i'll get the base map for my car? because i want to get it running.
thanks josh
« Reply #83 on: October 01, 2011, 04:58:12 pm »
Should be with you by Monday Josh.  :)
Offline josé
« Reply #84 on: October 01, 2011, 06:34:41 pm »
thats brilliant, hopefully i can get it running etc, then arrange a date for mapping.
thanks josh
Offline grungeisdead
« Reply #85 on: November 30, 2011, 04:23:30 pm »
Have you got a map suitable for the following
T25 Turbo
G60 Green Injectors
250kpa MAP Sensor
GT Camshaft
GT Inlet
Dewedged TB
Jabba Induction Kit
6psi boost switch
Basically I have an unknown turbo map, unsure if it can be unpicked to find out what spec its for, but I do want to upgrade to a 250kpa map sensor and G60 greens (currently running std MAP and G40 injectors)
ta
« Last Edit: November 30, 2011, 04:45:11 pm by grungeisdead »
« Reply #86 on: November 30, 2011, 05:25:37 pm »
Not got owt like that off the shelf Saf, would have to be a custom map. I've yet to see a car that has a true 'T25' map - all I've seen so far have been copies of Marshall's old chip, which was a G40 greens map with shitloads of fuel thrown in above 4000rpm.
Greens will be pretty much on their limit at 200bhp on a G40, so depending on what boost levels you're thinking of running, you may want to get larger injectors.
Offline poloandyb
« Reply #87 on: November 30, 2011, 09:42:26 pm »
hi im after a chip please for a g40 engine with gt manifold,r1 charger,intercooler,65mm pulley,slightly ported head and manifold,exhaust.
future plans are g60 injectors,4 branch,51mm throttle body
could you please tell me what might be the best chip for the job thanks
« Reply #88 on: November 30, 2011, 10:39:05 pm »
No worries fella, idles well and drives reasonably well, but I've always known it'll need a decent map for longevity and just to drive as well as it possibly can.
I'm not wanting to push massive power, the 170bhp that the g-ladered lump was more than plenty, and probably what I want to run with this, means it should be quick and reasonably reliable.
Whats your available like over Dec/Jan for mapping? and what sorta price we looking at? Is it done by the hour, or X amount for a mapping session and Y for tweaking later?
It is worthwhile getting larger injectors now, and getting the map done to suit, or just sticking with the greens if im happy around 170-180?
« Reply #89 on: December 01, 2011, 08:46:23 am »
G40003 would suit your spec. Priced at £50 plus £5 P&P. Email: chips@poloperformanceparts.co.uk to order.
Please note I'm currently away with work, so it might take 10-14 days before I post your chip.
