New G40 Maps- In Stock!!
Started by Yoof, January 10, 2009, 10:34:29 AM
Don't jabbasport normally call that an R1?
matthg40
yes mate i put that on  my original post pete asked what the r1 meant  ;D
matthg40
oh yes so i did my bad must have had a blonde moment apolagies for that matey ;D ;D
Quote from: matthg40 on November 01, 2010, 06:34:09 PM
oh i forgot to ask how would an uprated map sensor help my g40 my polo boots just over a bar of boost if you need to know that
If it's only just over a bar I'd stick with the stock MAP sensor.
You using standard head, cam, bottom end and intercooler?
matthg40
im using my standard head and cam i only gained the extra boost due to my toothed belt and pulleys ill stick with the standard map sensor im just rather keen to remap my polo so if someone can get back to me with an answer that would be awsome thanks
langersG40
Hi im interested in one of your chips stage 1 what some of gains HP and Torque wise would i get from it??
many thanks
chris
#67
Quote from: matthg40 on November 07, 2010, 09:49:21 PM
We charge £300 for a G40 remap which takes a day with you driving and me mapping. Email enquiries@PoloPerformanceParts.co.uk if you're interested.
Quote from: langersG40 on November 14, 2010, 08:59:36 PM
many thanks
chris
What's your current spec? We do chips to give safe fuelling and ignition timing for a certain spec - or full remaps to wring every last bit of power from your engine. Power gains will vary depending on your specification and what chip you're currently running.
langersG40
at the moment its got the standard chip, and pulley, want to put 65mm pulley on with your chip and get my injectors cleaned by you to, just wanted to gain a bit more power than standard, what do you think i would get from the above too? ball park wise? sorry for this question new to G40 ownership byw :D
thanks in advance
chris
matthg40
my spec on my polo is as follows
jabba sport r1 supercharger
g60 injectors
bored out ported and polished de-wedged throttle body
toothed belts and pullys running a 60mm pully
powerflow stainless exaust system from cat back with cat removed
so i would like to know which ecu chip would be best suited to my car many thanks matt
xandyx
can you please tell me whats the rev limit of #G40001?
i want to go from totally stock to a 65mm pulley and i'd like a chip to match! i have in the shelf a sns nolag but i think it's too agressive for such mod.
greetings
André
xandyx - Rev limit is 6600rpm, but can be changed to whatever you like.
matthg40 - G40003 is best for your spec. Do you really have a 60mm pulley? 65mm is normally the smallest size used.
Any new enquiries, please email our chips address:
chips@poloperformanceparts.co.uk
vwmk3jon
Can i order a chip please? (G400009)
Email the above address and we'll sort it. A full engine spec list is also helpful in your email, we have several 'flavours' of each chip so try to give you the most appropriate setup for your mods.
