Clear out of parts that are not required
Started by Jezza-7, September 19, 2015, 08:38:31 PM
Hi there, i have got a lot of parts for sale. Mainly from antony's car we was breaking but some are of my own.
Some are listed on eBay currently but will do them cheaper for you guys on here. Some of the parts are if not obsolete, very hard to come by, like the genuine sun roof seal i have.
Anyway here is the list, prices are ruff prices (not posted) and i will take offers as it all needs going. I will post all parts and i am going santa pod on the 4th october so i can take parts if needed. I will require a deposit of the part so that i song waste time and space.
13" spare wheel, completely original with factory fitted tyre £30? (haven't a clue)
Club Polo floor mats £25?
G40 flywheel, £20
Coilpack £15?
Indicator and light stalks, £15
Parcel shelf supports £20?
Genuine windscreen seal £40
Rear view mirror £5
Fog light switch x 2, £2 each
Headlight switch with dimmer £5
Rear window de mister £2
Rear strut caps, possibly for sale, £10
Bosch S5 battery, Collected, £30. Believe these are near £70 new?
Genuine arb mount/bush, only 1, £5
Brake servo £20?
powdercaoted engine/gearbox mount £15
Window winder £2
Either front or rear bump stops, £10. Think they are front.
Little grab handles that come from b pillar £10
engine mount with rubber, still good, £10
1 front suspension top mount £5
window seal/strips inside and outside total of 4 £10
scuttle tray, pretty much all in 1 piece with rubber seal £20
blower control surround £5
big bag on pic 1 is a G40 diff with bearings £50?
gt/g40 throttle bracket £5
metal driveshaft cover thing, £5
starter motor £20
G40 water stat housing, incl both genuine switches, thermostat and elbow £40. Please bare in mind that the switches are about £20-£30 for both.
Gearbox flanges £30
5 silicone pipes, will get measurement of hoses on request and prices
Bailey dump valve with silicone pipe, ideal for use with G40 throttle body £20
From and to rad coolant pipe, to and from blower, single from water pipe to thermostat housing, to expansion tank. Total of 5, £15
Seatbelts, front £15
1 x PPP Map # G40008 please see link for details: http://www.polog40.co.uk/forum/index.php?topic=1217.0
1 x chip is a custom map by ppp for a k03 turbo, 1341cc bottom end with accralites, ported head, 315cc injectors, 51mm tb, gt inlet, FMIC, turbo cam 268/268. Not sure on the price for that? PM if interested.
2 headlights, passenger genuine, driver is not £10 each
rear seatbelts incl middle one, £20
8v hyd tappets, 4k use, ideally these should be used with the cam that was used, but if someone wants them £15
Gearbox/engine plate £10
heater blower motor, just missing the connection to turn it off/on via cable £20
gearbox lower plate £10
exhaust hangar from back of block £5
Blower resistor £10
Chassis bracket to stop exhaust hitting floor, i think, £10
t piece with both oil pressure switches £15
ECU holder/brakcet £10
G40 fuel rail, missing one plug but can be sorted with a new one £15
Inlet manifold to ISV Pipe £5
G40 ECU white pipe from servo line to ecu £5
Possibly vac pipe from inlet manilla to brake servo, silicone join on bottom, £15
G40 sun visor's £10
1 RH side door grip £5
1 hanbrake cable £10
Green tint window, non genuine, £30.
Tiger6*2011
Hi mate need all engine mounts for my g40 lump think there are 3 do you have them all thanks
