Oil Temp
Started by Brace13, September 03, 2015, 08:33:31 PM
Brace13
Hey,
just a quick question if anyone can help.
is there a temp the oil should run at? and do any of you run oil coolers?
Worried mine may be running a little hot and considering a cooler but i honestly dont no anything about these engines yet.
cheers in advance
kwijibo_coupe
I run an oil cooler and my oil temp stays between 60-70 degrees when driving on the roads.
Brace13
ok cheers is that about what they should be then?
depends where you take the temp reading from. Mines in the sump and stays at a constant 50 degrees when cruising on the roads.
When i ran it in the head it read a lot higher like kwijibo's readings.
