G40 - melted piston
Started by Sknight92, July 31, 2015, 08:27:33 PM
Sknight92
Evening chaps,
I haven't been a member for long, nor an owner of a g40 for much longer. Had the car 6 months, and the charger shit itself, chucking oil and somehow a small piece of metal into my engine - result is piston no.3 melted. I've decided to go down the forge route. Where is the best place to get wossner pistons from? And what size complys to which cc, I think I'd like to convert to the 1.343 cc is it? Only charged dubs I found very helpful, only place I have found Pistons and charger rebuild? Just some advice where to go would be greatly appreciated.
Sam
There's quite a lot of sellers on eBay selling the pistons. You want 77mm for 1341cc.
dekerf1996
TSR performance, jabba and Phil J sell the pistons in this country
Pete off here could be the person you need to speak to regarding the charger if part of it is actually broken, as he sometimes has spare parts and also rebuilds them
Although i thing i find strange as how parts of the charger in the engine could cause a melted piston? Damage, yes but to melt the piston? Might point to a fault before the charger let go?
ereeiz
Look in the classifieds, there tends to be at least one person breaking a performance engine at a time, been quite a few the last 6 months.
JoeH
mmm isn't there a little gauze somewhere after the charger but before throttle body to stop these issues?
Hopefully you should find enough help on this forum to get you fixed back up :)
randombadger69
#5
There is a gauze trap after the charger, in the inlet of the intercooler as standard.
I've used both TSR and PEC for the pistons. PEC are very helpful from personal experience.
Pete or http://www.roettele-racing.de/page/niki-schelle.php for the charger rebuild.
Roettele racing could also provide pistons. They use wiseco in a lot of their builds.
Sknight92
Thanks for all the replies chaps, certainly appreciate it! Well, I'm unsure whether it was metal from my charger. But after it chucking the oil through my engine I checked the dipstick (after I'd stopped, and found a small piece of metal on my dipstick) assumed it was from my charger however my spark plug was melted to bits. Whether all the oil went down that particular cylinder - obviously you can compress oil so that may have done it.
Will check out the websites now,
Regards
Sam
