Author Topic: Seperate oil Supply For The Charger  (Read 2951 times)
Offline chasesfc
« on: January 08, 2009, 05:27:40 pm »
Hi Guys
i have heard of people on here running a seperate oil supply to the charger. i was wondering what you used for this. was a electric oil pump required.
any info or pics would be appreciated
cheers
marc
Re: Seperate oil Supply For The Charger
« Reply #1 on: January 08, 2009, 08:47:20 pm »
Facet fuel pumps are what most people use, only about £20-£30 quid to buy new. There is a wiring diagram in the electrical FAQ section :)
In an ideal world you'd use a proper electric oil pump but they are £150+ to buy.  The Facet fuel pump will do the job as long as you stick to using thin oil in it. I used thin fully synth or compressor oil in mine when I had one.
Offline chasesfc
« Reply #2 on: January 09, 2009, 11:48:51 am »
cheers buddy
i know i saw a mocal one for 150 on demon tweeks. a bit pricey. i will have a read up on them.
thanks again
marc
