My MAP sensor popped out of the boost pipe this week. Thankfully I didn't lose the clip, but when I went to put it back in I realised the rubber O ring was missing.
I've replaced that, and I assume it disappeared while the car was in the garage (hence why it popped out). But even with a brand new genuine seal, the MAP sensor seems quite loose. I can't pull it out but it can move a bit if I prod it with my finger, and I can't remember whether it did that before.
Is it fitted correctly? Or should the clip slot through the collar on the boost pipe, as on the coolant sensors? Does yours wobble? I can't work out if the missing seal was the cause of it popping out, or a symptom.
