Author Topic: Bearing has nipped/fused onto shaft how do I get it off?  (Read 3337 times)
Offline timmyb
« on: May 13, 2015, 10:38:10 pm »
Think it needs pressing but looking for advice
Offline Matty!
Re: Bearing has nipped/fused onto shaft how do I get it off?
« Reply #1 on: May 14, 2015, 06:26:32 am »
Tried applying heat to the bearing carefully with a Blowtorch?
« Reply #2 on: May 15, 2015, 12:46:16 pm »
are you talking about the rear bearing?  fused to the stub axle?
I'd probably just get a replacement stub axle.  I'm sure someone on here will have one knocking about.
Or cut into the bearing with an angle grinder till it's nearly through and then whack it with a chisel in the cut.  You might find the heat alone from cutting into it with the grinder loosens it too
Offline timmyb
« Reply #3 on: May 18, 2015, 10:13:48 am »
Cheers I got it sorted thank you for your help
