Author Topic: Opening the bonnet.....  (Read 3481 times)
Offline SamG40
  • Take.... on.... me....
« on: May 10, 2015, 01:50:56 pm »
....with a snapped cable. Has anyone a good way of opening the bonnet with a snapped cable?
Offline Andy
Re: Opening the bonnet.....
« Reply #1 on: May 10, 2015, 02:03:21 pm »
Front grille out, then pop the catch.
Offline physicsfool
« Reply #2 on: May 10, 2015, 04:55:47 pm »
You can also reach under and up
Not the hardest motor to break into that's for sure
Offline SamG40
« Reply #3 on: May 10, 2015, 05:55:57 pm »
I've not had a proper look at it yet as I'm still feeling a bit poorly from earlier on in the week (ahhhhhh) but I was hoping it would be easy enough with the grill out. Not to worry too much if I kill the grille as I've got a spare.
To make matters more interesting the squeaking alternator belt that I had has finally given up and popped off now the bonnet is stuck shut! Great.
Offline physicsfool
« Reply #4 on: May 10, 2015, 06:11:17 pm »
The part of the latch you push down on is to the left of the mechanism and of the VW badge. A hooked screw driver type thing will sort you out.
And you can just replace the cable with a bike brake cable
