Pipercross Performance Filters NOW stock at Opie Oils
Started by oilman, March 27, 2015, 03:27:51 PM
oilman
Good news, Opie Oils have extended the range of performance air filters available with the addition of Pipercross.
The Pipercross range NOW available at Opie Oils includes:
- Pipercross Replacement Air Filters - Find the correct Pipercross panel filter here > > >
A Pipercross panel filter will provide the simplest, most effective entry point into the range and fully utilises the Pipercross layered multi-density foam technology and lifetime construction. These filters can be cleaned and re-used year after year, Opie Oils stock the Pipercross cleaning products too, you can find them here > > >
- Pipercross Induction Kits - Use our Pipercross Induction Kit lookup here > > >
Pipercross Induction Systems remove the restrictive factory airbox to offer the maximum possible airflow into the engine. All filters use Pipercross composite airflow technology and systems are only released for production when they are bench-flow tested and make an improvement in airflow performance.
We also stock the Pipercross Viper Induction Kits which are the top level induction kit from Pipercross. Viper Induction Kits replace the original restrictive paper air filter and airbox with a high performance, carbon fibre sealed airbox. The carbon heat shield is bonded directly to a 150mm polished alloy rampipe to greatly increase laminar air flow within the filter, and maximise power.
- Pipercross Universal Filters - Prices from £17.21 before members discount
Over 70 universal Pipercross filters available at Opie Oils, prices start at just £17.21 before members 10% discount!
- Pipercross Venom Air Intake Kits - Prices start from £125.21 before members discount
The all-new Pipercross Venom Air Intake incorporates a new double-conical air filter design to increase surface area by over 40% when compared to a standard shaped cone. The double-conical filter gives the New Pipercross Venom the largest surface area of any aftermarket enclosed intake system of this type available today. Increased maximum air flow and low restriction for any given volume of air flow and increased dust capacity means less servicing is required.
- Pipercross Cold Air Feed Kits / Pipers - Prices start from £25.52 before 10% members discount
Pipercross cold air feed kits supply cold air from the front grill/bumper straight to your induction kit. Giving maximum power and enhancing the look of your engine bay.
- Pipercross Crank Case Breather Filters - Prices start from £20.39 before members discount.
Crank case breather filters are designed to prevent contaminated oil vapour from entering back into the engine. To be attached directly onto your existing crank case breather hose, the foam filter inside the case is resistant to chemical erosion.
- Pipercross PX300 Single Carb Series - Baseplates and filters
Designed for road and competition single carbs, the PX300 consists of a lightweight ring plate bonded to a high performance air filter element.
The element is made from reticulated foam in a triple layer laminate, with the filter being supported internally by a metal cage.
The PX300 is designed for use on a large range of carburettors as the baseplates are ordered separately to ensure the best combinations for your engine. When ordering elements, Pipercross advise to fit the largest possible, allowing a 19mm gap between the trumpet mouth or carb face and the inner face of the filter.
- Pipercross PX400 Formula Ford Series
The ultimate filter for Formula Ford and Superstocks.
Available as a lightweight throw away filter, designed to be changed at every engine build. Can also be fitted on any car using a Weber carburettor DGAV, DGV, DGAR, etc.
- Pipercross PX500 Small Twin Carb Series
The PX500 range of filters is developed for twin carburettors but in a compact design for applications where space can cause an issue e.g. Motorcycles, MG Midget, Metro, Mini etc.
The range consists of a filter unit which utilises the Pipercross competition foam, bonded to a ring plate. This ring plate can be attached (using the supplied DZUS fasteners) to either a tailored base plate or a blank base plate so you can cut the holes to suit your application. Remember to leave at least 20mm between the end of the trumpet/carburettor inlet and the inside of the filter.
- Plus a range of Pipercross Accessories
Pipercross accessories available at Opie Oils include filter servicing kits and Alloy Ram Piper trumpets.
Together with Pipercross and K&N, Opie Oils now offer an extensive range of performance air filters. If you have any questions regarding Pipercross or other any product we stock then give us a call on 01209 202949, drop us an email to sales@opieoils.co.uk or just ask us on the forum and we will be happy to help.
- Opie Oils
