Putting a k03 on my abd engine :)
Started by Buxton, December 20, 2014, 01:28:43 PM
Buxton
Hi I'm putting a r5turbo carb on my abd engine standard compression ratio (9/5/1)
Anything I need to keep in mind? I'm running 15 degrees timing on a mechanical mk2 dizzy at the moment I'm on bike carbs, but I'm hopefully fitting aftermarket ignition like nodiz megajolt ect, aiming for low boost about 6-10 psi? Maybe more? Cheers for any help and advice, I'm also purchasing a wideband and the abd already has a Newman 268 268 fitted :)
