Author Topic: Worth getting a adjustable fuel regulator  (Read 2124 times)
Offline John-125
« on: December 18, 2014, 08:41:01 pm »
Rebuilding my G with a g60 charger
With 315cc injectors and uptated fuel pump think it's worth getting one ?
Offline Alexiskayak_7
Re: Worth getting a adjustable fuel regulator
« Reply #1 on: December 20, 2014, 12:13:39 pm »
If you are not running more than 230ps its worthless.
All you need is to properly map the car (if you haven't)
« Last Edit: December 20, 2014, 12:19:47 pm by Alexiskayak_7 »
Offline marky-x5
  • If in doubt flat out
« Reply #2 on: December 20, 2014, 05:46:04 pm »
Can I ask what you are doing regarding MAP? I've got to the stage where I'm almost finished with the mods and was hoping to find something off the shelf for now. Unfortunately this hasn't happened and looking to get a custom setup.
Should add that I've also g60'd my G
Mark.
Offline John-125
« Reply #3 on: December 25, 2014, 08:51:24 pm »
Hello m8 yeah I'm in the same boat :/ what spec is your engine cam and injectors ?
Offline marky-x5
« Reply #4 on: December 26, 2014, 10:27:51 am »
I've gone for the 276 schrick cam and a set of volvo 315cc injectors. The head is off at the minute and I'm in the process of lightly porting and matching it.
