NEW windage tray. £30 posted
Started by PeteG40, November 10, 2014, 08:56:56 PM
new - when used stops crank splash which inturn helps retain momentum and therefore crank speed up/slow down.
As sold by max-rpm.
http://www.maxrpm.de/Racing-windage-tray-for-Polo-1-2-2f-likewise-G40
'Oil windage tray for all Audi 50, Polo 1, 2, 2f (MK1, MK2, MK3, likewise G40).
Prevents splashing the counterweights of the crankshaft into the oil in the pan.
Spezially in fast driven corners it makes also sure that the oilpump is getting silenced and cooled oil instead of dangerous air!
Easy mounting between the engine block and the oilpan.'
May need some slight trimming/modding for a g40 (so i'm told - but max site doesn't mention this)
£30 posted.
Will need modifying as mine was the same and had to be trimmed. Not a lot though.
Highly recommend these as well!
superchargedpolo
Pete,
I'll take it.  PM your details and I'll transfer some dosh.
Don't ask, I'm about to buy my 6th G40!  :D
Craig
Sorry Craig someone jumped on before you.
Will let you know if it falls through.
