temperature sensor
Started by G40_POWER_AD, November 02, 2014, 10:56:55 PM
G40_POWER_AD
I forgot to connect the plug of the blue sensor but the engine start in the same way....should not work ?
it'll still start and run but the ECU will show a fault code and be in limp home mode.  Just reconnect the sensor and drive it for a while and it should go back to running normally.
G40_POWER_AD
