HELPO! Eradic idle after de-wedging throttle body
Started by Merrick, October 02, 2014, 05:42:52 PM
Merrick
Hey hey, I've recenrly de-wedged my throttle body and now when warm it hunts on idle from 800rpm to 1100rpm? I've tried the ticker screw but that hasn't seemed to solve it. It also nearly stalls sometimes when you start it up and it's already warm. I heard somewhere your supposed to set the tick over with temp sensors unplugged it this correct?
When the engine is cold it ticks over just fine. Anyone any answers????
Freddy77
When dismantling to de wedge you may have disturbed the throttle closed
Microswitch. I changed mine and it de seated the microswitch slightly
And caused hunting. Just get someone to touch the pedal and see if it
Clicks it it doesn't its not making properly.and adjust to suit
You unplug the blue temp sender to do timing and possibly idle. Cant remember off the top of my head but there is a faq on it. I think you do have to set the idle up correctly though.
Could be a sticky valve, sticky throttle cable and also air leak will cause that problem.
Its quite a common thing though. My tb did it for a while until i squirted some wd40 down it. Sorted it out as mine was sticking slightly.  ;)
Merrick
how have you sealed the holes in the throttle plate?  Are you sure they're a good seal?
Merrick
Yeah holes where sealed. Took blue temp sensor out and adjusted idle screw now fine :-) thanks guys!!!!
