Oil Pressure Light - Left Hand Bend
Started by Matty!, September 10, 2014, 10:23:59 PM
Matty!
Orite lads,
this is happening a fw times now on a long left hander off the A19, Usually going into it balls deep hanging off the back of my mates 205gti...
What do I go for, ones of these baffled sumps?
http://rpm-tuning.de/glader/g40-tuning.htm
Or maybe a cheap option:
http://www.maxrpm.de/Racing-windage-tray-for-Polo-1-2-2f-likewise-G40
Or this - the full shabang
http://www.maxrpm.de/Aluminum-oil-pan-with-oil-scots-and-cooling-fins-all-VW-Polo-86c-G40-inclwindage-tray
This is all in prep for the 'ring next month and the fact that if it lives, its going to be turned into a more track focused machine.
GR40
Hahahahaha had the same happen to me 2 days ago on a long left though. Light popped an then turned off as soon as the car came back straight. I blame my standard suspension as this never happened to me when the engine was in my lowered on kw g40.
Matty!
Anyone?
And its happened on both suspension setups for me! :(
Ben.lopo
I changed all switches and found out to be wiring at fault check all earths ;-) happy searching
Alexiskayak_7
Ben.lopo
Matty!
GR40
Any updates to this topic! This might help me with my similar problem.
Alex
If you don't have an oil cooler then it's definitely worth investing in one.
However, mine used to do this and the problem disappeared after I renewed the oil lines to the charger.
Try the oil cooler first because if it is that, then at least you get an oil cooler out of it.
