Since fitting new Koni springs, shocks and nylon ARB blocks years ago, there is often a knocking sound coming from the LH strut. It's intermittent, but usually happens when I release the tension from the steering wheel after having it turned right, either when stationary or at low speed. It sounds almost as if something is moving slightly when the tension is released. I've checked the suspension points on this side and the closest I have actually come to finding it is if I put my hand in the cap at the top of the strut when the tension is released, I can feel the knock. Although I can't see any movement anywhere! The spring appears to be secure and seated correctly. I've checked the castle nut and top nut on the strut is tight. There is no movement where there shouldnt be in the steering linkage. The suspension mounting points (ARB, TCA etc. are all tight and secure. I can't think of anything else to check now.
Has anyone got any ideas?
