Lupo/Polo 16v
I've got a Lupo/Polo AHW 1.4 16v head (flat) that Rolette Racing use in Germany. It's re-manufactured, looks like new with valves, no cams or rocker cover. To use this I think you need to:
1. Weld up a water way
2. Sort out a cam belt idler
3. Fit cams required for supercharging/turbo charging
Might be able to use stock pistons with cut outs or perhaps N/A pistons with big enough cut outs to drop CR and take valves - if you have an eye on budget.
Many people would deem this head inferior to the AFG (Mk4 Polo) 16v head as it has rockers instead of cam direct on tappet. This is because the head wouldn't take the same RPM as a modified AFH head...but with a boosted engine this isn't an issue as you'll be making all your power at sensible RPM. Prob. below 7000rpm; at which point this had is fine
Of course this head would be suitable to give to Rolette and have them carry out any modifications required. Would be persuaded to part with head for £100 posted. I had it on eBay end of last year for a week, but no takers. Currently on eBay there is one for £120 and another at £375 that I can see. I'd keep it and use it in future, but pumping money into suspension now more than engine work.
AFH Head
From Mk4 Polo 1.4 16v. No need to weld up water way on this but still requires idler, cams and either custom pistons or finding an OEM piston that'd give correct CR.
