Hi guys,
I haven't had a lot of luck with this now and getting fed up.. please help me
I have recently converted to turbo, and it was running fine until...
I snapped a rocker bolt so I took the rocker off and got the broken stud out.. I had to remove the dizzy and the end cam cap thing
Once I fit back together I went to start it... the engine was turning but there was no fire
I noticed the fuel pump wasn't priming and the relay was slightly clicking when i turned the ignition
I unplugged and cleaned the fuel relay and then it fired fine
But it has developed this hesitation only sometimes .. It's like it cuts all the fuel for a second and really jolts?
Things i have triedI have just changed the in line fuel pump and fuel filter and I have changed the fuel pump relay and it has done bugger all ?
I have changed the distributor and dizzy cap
Sometimes it wont start again until i take the fuel relay out and put it back in, but it has got this constant hesitation
Could it be anything to do with the ecu relay playing up?
If anyone can suggest anything that might help i would love it as to top it of someone crashed into the back of me so i'm thinking about breaking up if this doesn't get solved
Thankyou
Rich
