hydraulic throttle cable?!
Started by z3i, April 30, 2014, 01:33:10 PM
z3i
Don't really understand this, not much came up on Google. But looking up pedal boxes on the net and alot of the ones with the design I'm looking for have a master cylinder and hydraulic accelerator? Is something like this possible? Never seen it before and can't find much info on it apart from a few kit cars
Is it a worth while mod? Is it as simple is making brackets for a slave cylinder at the throttle butterfly mechanism or is something I have missed? Apparently it makes for a very smooth throttle
This is an oxymoron surely?
I don't know any pedal boxes which have a hydraulic accelerator... plenty have a hydraulic clutch (which I think is what you mean?)
Polo clutch can be converted to hydraulic, leave the throttle cable, and the brakes hydraulic...
I don't know f anything which runs a hydraulic throttle, cable, rod, electronic yes, hydraulic, no  ???
Etches
Didn't realise it existed, no real need to reduce the effort levels of a cable/rod set up
z3i
Not hydraulic clutch, I'm looking at pedal boxes as I'm going to convert to hydraulic clutch. Definitely hydraulic accelerator. Apparently it's common. Conversion on dune buggy/sand rail type things? From what I've been reading I don't really get it, it's definitely a thing lol not me being stupid
I don't understand why on the motorsport pedal boxes I'm looking at it has a mastercylinder behind the throttle pedal? Another behind brake pedal and another behind clutch?
I thought I might convert my brakes to cable yoof.. :P
Unless I'm being stupid and there's two master cylinders, one for front and one for rear? They just placed the one for rear behind the throttle?
You've already got a cable brake...
Anyway- the pedal boxes you're looking at with 3 master cylinders will have 2 for the brake and a single for the clutch.
I've never heard of a hydraulic throttle... can't see any reason for one either.
z3i
Quote from: Yoof on April 30, 2014, 05:47:54 PM
Apologize for my retardness :( they defo exist though! the only benefit would be it not seizing up in arctic conditions? just a guess, i know sometimes you can get water in the outer casing and then it freezes? just a guess
again sorry for this, it was confusing the hell out of me, put was just my stupidity, i read into pedal boxes and i now see the balance bar controls both master cylinders
i hear your coming this weekend? woop :D
RyanC
i never seen a hydraulic accelerator in my life. most motor sport pedal boxes have two master cylinders for the brake pedal don't they?
z3i
Quote from: RyanC on May 01, 2014, 06:27:30 PM
Yes... Yes they do... I've always been under the impression they have one lol, now I know
Google it, definitely exists! Regarding pedal boxes depending on what master cylinder I get it should make a huge difference in pedal feel?
RyanC
U don't need a hydro throttle man, hydro clutch is a good idea and easy to do but that's all u will need, plus u would have a slave cylinder by the TB and would look messy, cable dose the job fine imo
